  1. Member archaeo's Avatar
    Mar 2004
    mountains
    On the fly (disc to disc) OR Hard Drive to disc?
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Hard drive to disc.
    On the fly is not recommended.
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    i agree with bazooka but you could do on the fly as long as your dvd burner and dvdrom are not connected to the same IDE controller. if they are on the same IDE then make sure the reader speed is at least double of the burning speed. i've done some disc to disc copying that way without any problems.
  4. Member archaeo's Avatar
    Mar 2004
    mountains
    thanks for the feedback. If I burn at 1X, that should keep it well below the read speed...
  5. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    wouldnt they both be the same
    a backup is a backup, if you got the grunt to do on the fly and it completes successfully then it should be the same.
  6. I would have to agree with Sifaga. I'm new to the DVD world but this used to come up all the time when burning CDR. I know DVD burning is a lot more data and might take some more umph from your computer, but isn't that what the buffer is for on your burner? I'm just asking. But it seems to me if the burn completed then you should have an exact copy, either way. The only benefit I see is that if your computer can't handle the stress, than yeah the hard drive to disk may be safer, but if it can handle it, it would be the same.
    I do 4x on-the-fly just fine.
  8. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    ditto......all the time.
