trying to convert a movie and im not gettin any video in the tmpgenc? any ideas?
have you read https://www.videohelp.com/forum/viewtopic.php?t=193316 ?
yup read that...nothing there about video...i got no video preview no nutin..just load video file and it stays black...try n convert..i only get sound playback.
If TMPGEnc worked in the past for you but does not work now then you need to consider a few things.
What changes, if any, have you made to your computer since? Installing or updating software, firmware, codecs etc. all count as does any hardware changes be it eliminating or adding hardware.
Are you sure there is not a problem with the AVI files. I admit this sounds somewhat unlikely since you said you have tried several different AVI files but the possibility still exists that the AVI files you have tried as of late have "issues" with them.
Usually when TMPGEnc "acts up" in the way you are describing it has something to do with the ENVIRONMENTAL SETTINGS.
I guess I would try uninstalling TMPGEnc and then reinstalling it. If that doesn't work then I would fiddle around with the ENVIRONMENTAL SETTINGS i.e., the tab called "VFAPI plug-in".
You might also want to try multiple method of importing your AVI into TMPGEnc.
For instance try:
1.) Opening the AVI directly into TMPGEnc
2.) Open the AVI in VirtualDubMod and frameserve to TMPGEnc
3.) Use an AviSynth AVS script to import the AVI into TMPGEnc
Another reason why TMPGEnc could be "acting up" is if you made any changes to the codecs on your computer. If that truely is the problem (and this has happened to a lot of people in the past) then it can be next to impossible to fix. Usually the only real way to fix that is to blow out your HDD and re-format and re-install your OS and programs, etc. but make sure you only install the codecs you ABSOLUTELY need.
I wish you luck!
It's a Gremlin. There's one running around loose inside your computer. You're going to need a five gallon bucket of water and a ball peen hammer to fix this. Send me a PM and I'll give you all the details.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Is that a cat with some sort of mellon on his mellon ... or is it one of the dreaded space alien cats from planet Kickurass in the STFU galaxy?Originally Posted by sacajaweeda
Either way I get the creeps looking at it! :P
You'll have to ask makntraks for the answer to that one. I'm just taking it for a test drive.
It pwns though, does it not?"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
TMPGEnc Video Organizer
By TBoneit in forum EditingReplies: 8Last Post: 14th Dec 2012, 20:28 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc 4.0 XPress - audio only no video?
By Trang-Ly in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 13:47 -
Text Over Video with TMPGEnc 4.0 Xpress?
By codeseven in forum EditingReplies: 1Last Post: 12th Apr 2008, 15:17 -
Tmpgenc producing Jerky video?
By love2learn in forum Video ConversionReplies: 7Last Post: 11th Nov 2007, 09:37
