A lot of people were stating that they were having either wierd dvd playback or complete lack of playback with the last few builds of the beta.
I have been wrestling with this all week and I think i have it sorted now in Beta 5. Please go grab it (from the registered users area) and post your findings here.
CB
Results 1 to 21 of 21
Hey Chrissyboy
Lots of problem with this beta.
In settings when I go to burning. I get "Nerocom.dll not registered. I had that in earlier betas. I can fix that by registering that dll.
Menu preview, I get an unhandled exception. No preview if I select continue.
Just before burning, I get the "SVCD2DVD Error" window twice.
When I try to burn the video_ts folder with Nero, I get "Video compliance test failed", or something lik that. If I select ignore, the DVD does not play.
I will send an e-mail with the log.
db -
Thanks for the info. I broke the menu making.... I have fixed it now - can you re-download & let me know if it is fixed for you?
Got the new one. One problem so far. Menu preview works. But I can't close the preview window. It stops responding. That's with MP3 audio. Without audio, it will close.
Just before burning, I get the SVCD2DVD error box twice:
Type: System.NullReferenceException
Source: System.Windows.Forms
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at System.Windows.Forms.Control.MarshaledInvoke(Contr ol caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at System.Windows.Forms.Control.Invoke(Delegate method)
at SVCD2DVD.d3764d4f1e921081.f81783e1b359ffc3() -
I burned it manually with Nero. The disc works fine. It didn't work in one of my players though. It would not read the disc at all. I am pretty sure that has to do with bitsetting. I just converted my Pioneer 108 to a Piodata 108 which does bitsetting for +R's, and +RW's. I used a +RW.
Not sure, could be.I am pretty sure that has to do with bitsetting
I'll pretty sure this is due to the fact that the SVCD2DVD window is not in focus. It is a known problem.Originally Posted by Dixon Butz
Also I have made yet another fix to the muxer - should be more compatible now. Feel free to redownload.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Looks like the menu preview is broken again.
When I click preview, the preview window takes a long time to appear. The window is black with no audio. No errorr or crash.
db -
I still get the "SVCD2DVD Error" window even with the window in focus just before burnin'.
InnerException:
yep broke the menu stuff again!!! Which explians "DVD-Video compliance test failed"
I will get a fix up there shortly.
Thanks for testing.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Fix applied. Sorry about that.
the cross on the top right doesn't work?
No. The window turns gray. And it won't close. If I click the x again, I get the Windows end program box.
ok. I think i know what the issue is. Leave it with me.
It turns out it was the bitsetting! I flashed back to Pioneer firmware. I then burned a DVD+RW made with Audio DVD Creator.Originally Posted by Dixon Butz
http://www.audio-dvd-creator.com/
And it worked. It didn't work in the same player when I burned it with the Piodata firmware. I still don't understand why. When I burnt +R's with the Piodata FW, they play fine. -
Hello I am enjoying this new program but I am having a problem with a error when I try to set burner setting. I get a error of Nerocom.dll not registered. I tried what you suggested
regsvr32 "C:\Program Files\Ahead\Nero\NeroCom.dll
I still am getting the error of nerocomm.dll not registered.
This is my first bug I have found I want to see if we can resolve this and I will post others later.
By the way iss where I should be posting this?
Computeman -
What version of Nero do you have installed?
Serious help needed for major project. Capture video from several cameras.
By meeio in forum Video Streaming DownloadingReplies: 3Last Post: 23rd May 2011, 01:15 -
Where is the Major... ??
By moon47usaco in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2010, 13:22 -
how can i download a major editor?
By maltesefalconese in forum EditingReplies: 4Last Post: 4th May 2010, 12:37 -
Need Major help from an expert!
By jbartosh in forum MediaReplies: 38Last Post: 23rd Oct 2007, 13:45 -
major problem
By Antitrust19 in forum ComputerReplies: 6Last Post: 28th May 2007, 09:30
