i made a snowboardmovies that is 31 minutes with a bitrate of 9300 with tmpgenc plus and then when i open it in tmpgenc dvd author ,i get this messages -a video sequence header is necessary for every GOP in a standard dvd. the video sequence header is incorrect
-the video GOP is too long .what did i wrong or forget ,thx
Other people have had this same error, and the common consensus is to just ignore the error, and the disc is fine. Or, you could use VideoReDo to rewrite the GOP header.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 1.6...
By acid_burn in forum Authoring (DVD)Replies: 4Last Post: 21st May 2008, 23:45 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
