hi![]()
having problems when burning film to disk.the film is in sync when viewed on power dvd, yet when burned to disk using nero the sync is out slightly
any idea's![]()
many thanks
are you just burning as dvd-video with nero? or are you converting to vcd,svcd? or are you using nerovision express and converting to dvd?
hi
I'm using nero express 6,>select dvd files from h/drive add files to vts folder and burn.I authorised the dvd with dvd-lab but every thing seems o.k. till burning.
firmware burning problem
By weedhopper in forum DVD & Blu-ray PlayersReplies: 6Last Post: 1st Aug 2010, 11:34 -
BDMV burning problem
By rickoshay in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jun 2010, 04:48 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 06:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39
