I've been using tooLame for the past several months and am quite happy with the results. There is one audio .wav file that keeps causing tooLame to crash. I've tried changing the different command prompts with toolame but it keeps happening. Are there any other mp2 encoders out there that I could try or some kind of utility to check the wav file with? I really need to because I already deleted the source file and the program that I recorded is rarely broadcast and has never been released on video.
Use SCMPX, I use it as a sample rate coverter/mp2 encoder when SSRC or tooLame fail. Search in yahoo (if you check here I posted the address earlier, it's in a topic about downsample).
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 19:27 -
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 10:48 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 22:32 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 12:50
