I want to make a music video using Adobe Premiere Pro 1.5, but the files right now are in the format .ogg. Adobe Premiere Pro 1.5 does not support this. Is there any way I could get it to except the format? Like download some plugin or maybe codec or something like that? If so please help me! Thanks in advance.
oh ya currently im doing the thing were not supposed to talk about on this fourm ^_^. but i mean a faster way, this wil take like 10 hours it looks like to do 26 videos. thanks in adavnce again.
Whatever you're not talking about; You can probably extract the audio with Virtualdub as a WAV. Then you would be able to use it. Check www.vorbis.com for info on OGG files.
BTW, This is just for the audio. The video may be XVID, but you would know that if you ran it through AVICODEC or GSPOT. -
aight i went and downloaded he codec but it still wont let me import it into adobe premiere pro ; /
i really doltn want to conver them all
(conversion is what i meant when i said not supposed to talk about)
any ideas o fhow to get the file into adobe premiere pro?
says the video is: XVID Mpeg 4 and audio is Ogg vorbis mode 1
thanks in adavacne
