what are the best settings in avi capture using virtual dub ?
Under tab video u have option format with 2 figures to fill in : size & pixeldepth (yuy - yuhu - rgb etc.)
Original is vhs video pal > settings ??
In the end its ment to be an dvd for play back on tv and/or divx to share ...
Thanx
i tried one on 320x240 yuy2 and that was not very good, but its analoge capture ... does other setting make it better on tv (pixel)
this menu (if im right) :
Results 1 to 15 of 15
https://www.videohelp.com/forum/userguides/89899.phpOriginally Posted by wijdbeens
yep i've read in meantime , but 352 x 576 (pal) gives a very strange picture (lets say i have to turn my monitor 90 to see it in good shape - or how do u say this), can't imagine thats oke on tv later ... for example 480 x 360 is more in shape, or do i see it wrong .... ?
(monochrome colours for small size .bmp pic)
[/img] -
If you are gonna make dvd will 352x576 look okey on your tv. The image will be stretched to correct aspect ratio, 4:3= 768x576.
VirtualDub error > Reduce image size (?) (radeon 9800 XXL)
Whats next best setting ?
Cant try em all .....
M -
If you have an ATI card then you can't really use VirtualDub as a capture utility. I mean there might be a way but it surely is not worth it.
ATI cards seems to work best when you use the special ATI software. You might want to try VirtualVCR but I don't know if that will work with ATI cards either.
LordSmurf (a long time member of this website) has created his own website that has a lot of general knowledge about captureing but leans towards using the ATI cards.
Here is that website by LordSmurf:
http://www.digitalfaq.com/
So in short forget about using VirtualDub with an ATI capture card.
Good Luck!
That's not correct! My Radeon AIW works fine with VirtualDub, AV_IO and VirtualVCR as well. It's a few years since I set my system up but I think all I needed to do was to install some VFW wrapper software and it's been fine ever since.If you have an ATI card then you can't really use VirtualDub as a capture utility
Well that was my point when I said that you probably could get VirtualDub to work but that it likely isn't worth it because installing a VFW wrapper for use with a WDM driver is a "tricky" thing to do, i.e., getting it to work correctly.Originally Posted by feenix
The ATI AIW cards works fine with certain version of virtualdub, but ATI MMC will give most control and best results. I do not currently have my virtualdub guides online (which cover basic use, plus some ATI notes, coming soon), but the ATI MMC guides are there. www.digitalFAQ.com
I've been on lordsmurf site before asking, lot of useful info, but i didn't read this gap anywhere ....
Wdm-driver correct, i didn't mention so think it's standard .... Read about the ati mmc software, but i don't have such on my pc, didn't come with my machine.
Rather by another card then ? Virtualdub was the only programm that did the trick for me in capturing analog (studio pinnacle 9 & ulead x have no audio) but only up to early mentioned sizes.
The whole project was a trial for me, now it's an case of honor to get it to work :P
M -
I could be wrong but ... if you have an ATI capture card ... even if it is a third party ATI card (like those Sapphire cards that use ATI guts) can't you just download the ATI MMC software from the ATI website for free?
When installing, got message "uci" not installed, may encounter some probs, what is it, what do i miss
@lordsmurf : i follow u in set-up but where do i start ? That TV - 8.1 pic thats your first, which chapter ? i only got eazyshare tv (9.01) and that doesn't work cause it cant find any servers ?
Where do i set my presets of personal video ?
Michel
(not the last post
Oke, did a custom re-install, and could check a "tv" box, so that's solved ....
Kick in a new thread if u dont mind, cause this is more about VDub and now i'm trying to get mmc to work ....
Virtualdub avi capture audio sync issues
By buckethead in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2011, 15:34 -
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
DV capture from sony HDR-HC9E to AVI thru virtualdub
By one1 in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2010, 21:50 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 14:42 -
If VirtualDub capture, which one and what settings?
By tluxon in forum Capturing and VCRReplies: 3Last Post: 20th Jan 2009, 21:05
