Can somebody help please.
I've just bought an Epson CX3200
Brought it home and am trying to install it.
When i put the disk in i get
16 Bit Windows Subsystem
C:\WINDOWS\SYSTEM32\AUTOEXEC.NT.
The sytem file is not suitable for running MS-DOS and Microsoft Windows applications.Choose 'Close' to terminate the application.
Close Ignore
Ive tried to ignore but nothing happens?.
Xp should already have the driver.
Select add printer in the control panel and see if that printer is listed. -
The CX3200 is a multifunction device (Printer, Scanner, etc.) Unplug it and place the install CD in in the drive. Plug in the USB cable and as bazooka said, XP should find a new device. Let the OS find the drivers on the CD. This may take a few minutes. If that doesn't work, try installing from the CD. You might want to go to the Epson site for updated drivers if you still have problems.
Problems Installing RipBot
By Dan_Joyner in forum Blu-ray RippingReplies: 8Last Post: 16th Apr 2013, 06:20 -
problems installing bd rebuilder
By davechubb in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2012, 03:09 -
Installing Problems, No file created
By jburkhardt in forum ffmpegX general discussionReplies: 8Last Post: 1st Nov 2008, 22:56 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 08:56 -
problems installing flash player
By stretchweider in forum MacReplies: 3Last Post: 29th Aug 2007, 09:51
