    Jul 2001
    Maryland
    I need to know how to resize image i paste into photoshop. I am trying to make a collage but i need to resize the multiple images i paste into the main image (a white 8x10)
    Help me
  2. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    select the layer of the image and go to your "edit" menu. Down to "transform", then "scale".
    If you want to keep the current ratio, then make sure you click the rubber band between the height and width at the top of the screen.
    I typically click the rubber band, then click inside the height or width box and then use the scroll wheel to resize.
    Jul 2001
    Maryland
    you have no idea how much more productive i will be now that I know that
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Screw all that clicking.
    On the layer you want to scale hit Apple+t (Alt+t)
    Click and drag a corner to resize
    Hold Shift and move a corner to keep aspect ratio
    Hold Option and move a corner to scale towards the center
    Hold Option + Shift and move a corner to scale towards the center and retain aspect ratio
  5. Is that before or after you have to force quit Mac Photoshop because it freezes when anything streneous is required of it?
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    To be 100% honest. Photoshop has never crashed on me. In fact none of the Adobe lins has crashed on me. They are very well written and extremely stable. Even on my 450mhz cube.
