Okay - I'm a newbie (that's the first step in getting help). I've got a number of instructional video tapes that I would like to capture a burn to a cd. They are anywherre from 60 minutes to 90 minutes long. I have a number of video editing programs which include uleade videostudio, adobe, mgi video wave and microsoft movie maker. I can capture video from my vcr - but am not sure what format to save in so that I can fit an entire tape onto one cd.
I've been going crazy surfing the web for some direction and found this site. It looks great. Hope you can help me.
Dov
dfeder,
Welcome on board. This is really a great site.
First of all, check out the "HOW TO" section on the menu to the left of the screen.
You have a lot of reading ahead of you. A quick and useless answer to your question is: you can capture to AVI and then process the image into an mpeg stream (which will then be "formatted" into a vcd or svcd) or capture directly into the mpeg format. Capturing directly into mpeg usually give really poor results....
Make sure to read the forum. You can click on SEARCH on the top of this screen and try to find people who had questions similar to yours and got answers...
best of luck.
EBaldino -
dfeder,
These questions may be able to help me. Sorry to use your topic for my problem, see topic "View TV on laptop'. But, may be you have not pass this stage.
Are you able to see the vcr movie on your pc, assuming your are using a pc. If you can see it, can you make it a full screen?
Thans, -
Thanks to all who replied either via the forum or e-mail directly. Eduardo - your recipie for success is something I will definitely try - first I have to understand each step and each program. And I WILL keep you posted regarding my success (!?)
Thanks again all - I'm off to dubland
Doug
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
VCR help Plus
By goldberg317 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2008, 10:14 -
Best VCR...
By Superstar24 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 00:28 -
Do you still have a vcr?
By yoda313 in forum PollsReplies: 52Last Post: 25th Nov 2008, 22:37 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
