I used to have a LG Multi drive that worked great with Memorex and Maxell DVD media but I recently upgraded everything on my computer and also got a New LG 4120b Drive for it and since then using the same media I've been getting alot of skipping and freezing I just updated the firmware to A112 just tonight so I'm not sure if this fixed it or not but I've been using only DVD-R 's to and getting these problems do you think switching to DVD+R would help or should I only buy great media ?
Let me know what you guys think please and thank you !
take a look at the LG forum at cdfreaks.com and post your questions there. http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=30&f=91so I'm not sure if this fixed it or not but I've been using only DVD-R 's to and getting these problems do you think switching to DVD+R would help or should I only buy great media ?
or you can post questions at cdrlab.com
http://www.cdrlabs.com/phpBB/viewforum.php?f=3&sid=2bd2aa40c0de1f73d676750c53d97336
i don't think changing dvd media would be the answer to your problem but it could also be the software you're using to backup your dvds. Posting the software that you use would be helpful for others to help you sort your problem.
I used Nero too, maybe that was it. Then again I use Nero with the NEC and everything works flawlessly.
I think I know why all the troubles tell me what you think.
My old burner I only used CloneDVD then I got my new one and switched to Nero I use shrink and Reaurthur just the main movie and take all the extra Audio and save it as an image.
then I use Nero and burn the image to disc but I have to choose all files before it sees the image I think this is way all the bad burns.
what do you think ?
Going to buy a 25 Spindal of Merorex tomorrow and test it out. -
I just had someone else tell me that some of the LG discs pause and skip. I think it's just an inferior burner. No one has ever had any problems with discs from the NEC. The LG discs used to take awhile to scan sometimes when I'd put them in a player, the NEC discs scan almost instantly.
Speedig up video - alot
By Cralis in forum Newbie / General discussionsReplies: 4Last Post: 15th Jan 2010, 08:36 -
Making alot of Bluray coasters
By bpstyxman in forum Authoring (Blu-ray)Replies: 6Last Post: 13th May 2009, 03:09 -
i need alot of help converting .avi to dvd?
By just in forum Newbie / General discussionsReplies: 17Last Post: 21st Oct 2008, 15:51 -
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
alot of info here..and I just got lost.
By bgd73 in forum Newbie / General discussionsReplies: 11Last Post: 12th Feb 2008, 21:41
