can anyone direct me to a good software that'll help me do that?
use bitrate viewer or use https://www.videohelp.com/calc and fudge around
i believe that only shows what the header is reported to be , not the acual avg bit rate (i could be wrong)Originally Posted by MOVIEGEEK"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
yeah in powerdvd it only shows current bit rate not the avg.
but I'm little confused about how interpret the result in bitrate viewer
do I need to wait until it scans through the entire VOB first?
cuz the avg bitrate keeps changing -
Yes it has to scan through your entire file, which can be problematic when dealing with separate vobs. Its best to rip the DVD to a single mpeg video stream. Go get a cup of coffee or something because it will take quite a while to load the whole thing.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Finding out the peak bitrate of a DivX file
By Anakin in forum Video ConversionReplies: 2Last Post: 8th Oct 2011, 16:25 -
hanbrake average bitrate
By scarlac in forum Video ConversionReplies: 4Last Post: 12th May 2010, 14:35 -
Trouble Finding Bitrate for DivX Xvid for CD-r
By 4194 in forum DVD RippingReplies: 9Last Post: 24th Aug 2007, 11:41 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 10:44
