Howdy guys
Im in the process of learing how to convert Xvid/avi/Svcd. I have a Xvid/avi file that im working on. Im using the DIKO tool and the Virtual dub tool to convert and Author the file.
Im working with the DIKO guide also on this site. Ive configured Diko and now im working with Virtual Dub. I'm up to a stage in the tutorial that I dont quite understand.
I think it is maybe step 5 in the Virtual dub part of the tutorial (after the Diko confuguration). Any way it says to Drop down the "file" tab in Dub and select and browse to the Video source- Ive done that.
Now the bit that i dont get. Firstly it says something about limiting the "quality" of the sample by selecting the button that is not "blurred". I dont know what button it is talking about- all of the buttons along the bottom of the Virtual dub window are clear ??
What does this mean?? , i cant find blurred buttons, is this important??
Thanks Yowie![]()
Howdy
Ok ive mucked around with DIKO and Virtual dub a bit more. I downloaded Subtitle Workshop and tried to find subtitles.
I still cant work that bit out. I dont know where any subtitles are. In fact I dont really understand their relivance and whether I need to worry about them.
But it does annoy me that i cant follow what appears to be simple on the tutorial. In fact- What are we actually talking about here?? What are the subtitles for and how are they relavant to the Clip.???
I had some partual success with VirtualDub though. I created a 1 minute Sample to Convert and saved it.
I then went back to DIKO and browsed to that sample and loaded it into the box in "New Conversion" window.
I then hit the convert button down the bottom of the tab. It went through a process for about 50 seconds and then came up with an odd error.
A little box came up that said:-
ERROR 19 Pulldown failed
Enabling the 3:2 pulldown flag via pulldown.exe
Returned an error flag. You can configure
DIKO to ignore this failure (sometimes it doesn't
cause problems).
Can someone please firstly tell me what the relavance of the subtitles and where to find them and also the meaning of the error 19 error
Thanks Yowie
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 13:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 07:45
