I honestly have no clue how to describe this but here it goes,
I created an MPEG file which turned outt o be way to big so I thought "Turn it into an AVI" which I was going to but it ended up being not that much smaller, so I figured WMV (it's a clip that someone asked me to get for them so I figure WMV would make it small and transfer fast) so I fire up Windows Movie Maker 2.1 and go through the stuff, load up my MPEG file and it's only one frame (not odd since the clips are about 6 minuts and the other is less then 30 seconds) so I drag it down to the storyboard and go to save it as a wmv... Well it then locks up and crashes on me every time.
I tried it with another MPEG file and get the same result I try it with an AVI file and it works perfectly fine but it has the (DIVX) logo in the lower right which annoys me since it's not a DivX AVI file anymore.
anyone know what could cause this?
Results 1 to 1 of 1
converting mpeg to avi or to wmv
By stevenr2 in forum Video ConversionReplies: 4Last Post: 11th Jan 2010, 15:56 -
QT can't parse error converting mpeg-1 to DV
By jglass in forum ffmpegX general discussionReplies: 3Last Post: 22nd Jun 2008, 10:57 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
WMV to MPEG gives error
By tommm in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:46 -
newbie: converting wmv to mov, mpeg, etc. = loss of audio
By adambolo in forum ffmpegX general discussionReplies: 4Last Post: 17th May 2007, 10:27
