  1. Anonymous
    Guest
    anyone use this? is better than the previous version?
  2. Banned
    Sep 2004
    Inner Circle of Thought
    I used to use it but then switched to powerdvd 5.
  3. Anonymous
    Guest
    why
    Australia
    Yes - I use it, it's OK - it is fast to load which is why I use it as the main DVD player, others seem to take a long time to start (and do disk thrashing in the process).
    It also plays DVD IFO files on network drives without argument - others seem to have trouble with this.
    Ironically it won't play files greater than 4gb (odd for an XP version).
  5. Banned
    Sep 2004
    Originally Posted by Dr.Gee
    why
    I had a couple of issues with xp4.
    If I remember the error message right, there was something wrong with the playing grid.
    Upgrading to powerdvd5 fixed that.
  6. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    i use it a lot. but once v5 came out i upgraded for the new features ect. i have now just got v6.
  7. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Same here, i used powerdvd xp a while, then upgraded to version 5 and now am using PowerDVD 6.
    PowerDVD 6 works well expect that i cant seem to play DVD Audio disk. Im going to contact technical support, maybe send an email.
