Results 1 to 14 of 14
  1. Member maek's Avatar
    Jan 2004
    Arizona
    Is there a software package or utility that will take a video file and modify it so that the new file actually plays in reverse?
    "What? Huh?!? WHAT will come out no more?!?" Jack Burton -- BIG TROUBLE IN LITTLE CHINA
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Videomach from http://www.gromada.com/VideoMach.html (30 day free trial) which will allow you to reverse (run backwards) any footage (There is an option in "Define Output" to "Save Backwards")
    I have never used this, but it might be a starting point.
  3. Member SaSi's Avatar
    Jan 2003
    Hellas
    Interesting topic. I recently wanted to do just that - for a limited size clip - and in absense of anything better to do I use VirtualDUB to save the clip as a series of images (img000001, img000002, ...). I then used an image viewer (Thumbsplus) to sort them in reverse name order and then used the auto-rename facility to rename then again in ascending numering. This virtually generated an image series of the video in reverse order which I then re-imported to Virtualdub to render as AVI.
    I would be interested to see if anything better exists.
    The more I learn, the more I come to realize how little it is I know.
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Media Studio Pro (probably Premier & Vegas too). Insert clip into timeline, right click, select reverse
  5. If you want to do it for free then you can use AviSynth and its Reverse filter.
  6. Member daamon's Avatar
    Melbourne, Oz
    All - Premiere 6.0 (and so, guess, similar versions):
    1. Insert clip on timeline.
    2. Right click -> Speed
    3. Set to -100% (minus or negative 100%) for same speed, just reverse. Of course, different %ges, different speed. Positive = normal / forward, negative = reverse.
    Works a treat...
    Anything else - no idea.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  7. Member maek's Avatar
    Jan 2004
    Arizona
    To all -- thanks for the input!! I do have AVISYNTH, but I didn't know a reverse filter was available. I'll give that a shot.
  8. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    You can do some pretty amazing things with AviSynth.
    As soon as I read the very first post in this thread I immediately thought, "I have no idea how to do this but I bet AviSynth can do it" hehehe
    I wonder though how well this would work with interlaced 29.970fps NTSC video?
    Wouldn't that cause all sorts of "issues"?
    - John "FulciLives" Coleman
  9. Member lgh529's Avatar
    Apr 2003
    Syracuse, Utah, USA
    You can do this in Vegas in about 2 clicks, and you can specify how fast in reverse you want it.
  10. Odd, but there are usually more topics about how to get a reverse playing video to play forward
  11. how to use this prog.???
    i installed avisynth but nowhere is main programe exe file!!!!!!
  12. only_emo_kid
    Guest
    why would u wanna? :P i'm curious....
  13. Member Cornucopia's Avatar
    AfterEffects. That's where you can do the fun stuff--start, stop, speed up, slow down, reverse, all within the same clip in the same timeline. Hell, you could probably do a "DJ scratch" of a clip! 8) (also $$)
    But for free, you can't beat AVISynth.
