Does anyone know if this player can do both?
The manual is unclear about it - the 622 definitely can...but not so sure about this one.
Will I be likely to get any problems if I am limited to PAL..ie. with VCD /SVCDs? or should everything play ok regardless?
The manual says you can switch by turning it off at the wall then holding play and ff when you turn it on to give you a menu...all I got when I do this is an electric shock from the bloody thing...
please help me before I electrocute myself
yes it can play both as I tried myself. the main thing you have to check is not the player really but the TV! The player will more or less play anything you shuv into it, but if the TV is not multi-standard, then black and white for you dude.
Any TV not 5 years old should play both Pal and NTSC no worries.
Just do like me and burn 2 VCDs, one PAL and one NTSC and take them to the shop, tell the salesman to try them for you and see what happens. Only to make sure the player is good for you and this worked for..... -
Cheers m8
My tv does pal and ntsc no probs - got a US Dreamcast thro it.
So have u ever had a shock from your player? or is just me...
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
