I have installed v2 and starting to give it a try but i would like someone to tell me how start the converting section,I mean after i have put all the clips in the VTS etc and created my menu`s i now need to do the last section on where it creates the audio and ts folder.
I have seen the example links on the site but it will not run on my pc as active x i believe has been disabled in a programe and can get it enabled again otherwise i would have watched them.
Or is there a mpg version of the demos and i can sort this out for myself.
THANKS.
