Results 1 to 11 of 11
  1. Member joelson's Avatar
    May 2004
    Brazil
    Hello,
    Is it possible to capture those old Super-8 films?? It's an old film, with no audio, and that has to be projected on the wall, in order to watch it.
    If so, how should I proceed?
    Thanks in advance.
    Best regards,
    Joelson.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could always use a modern camcorder and set it up on a tripod and record the video in realtime. Then dub the tape the normal way.....
    That's probably the quickest realtime method
    Kevin
  3. Digital Device User Ron B's Avatar
    Mar 2003
    The Gorge
    That's what I do. Try to set your camera's shutter speed to get close to the speed of the projector to eliminate flicker. Use manual focus and white balance.
  4. Member joelson's Avatar
    May 2004
    Brazil
    OK, doesn't it have an output? Just like RCA?
    Best regards,
    Joelson.
  5. Digital Device User Ron B's Avatar
    Mar 2003
    The Gorge
    Do you mean output jacks on the projector?
  6. Member joelson's Avatar
    May 2004
    Brazil
    I mean an output, which we can connect via cable.
    I've been asking around, and I've been told that there is a machine that scans the film (and too expensive too).
    OK, thanks anyway!
    Best regards,
    Joelson.
    canada
    Dont even record to tape,just connect rca out to your capture card while in record mode with a camera.
    Jan 2004
    GEORGIA US
    Check around for something like projecting it on a frosted glass and taping it with your vidcam. I know that this kind of a do it yourself site but if the super 8 movies are of extreame importance to you, you may want to see a pro to have them done. I remember a freinds family had a manufactured box that was like a little TV projection screen that they watched their home movies on
    IS IT SUPPOSED TO SMOKE LIKE THAT?
    Jan 2004
    GEORGIA US
    Holy Batshit! I went off to look for some info and found this site. If you got a week to read it. I am not promoting his services but it is some serious ranting. http://www.film-to-video.com/tutorial.html
    MODS I am not selling or endorsing the business only providing a link to anothers site if it is out of bounds feel free to pull this reply. Thanks ZAPPER
    Jan 2004
    GEORGIA US
    OK Again, Not an endorsement, Only a link, There is too much out there about this subject for my little mind to deal with at this hour of the night. You are going to have decide what is best for you. I am stepping away from it for awhile. http://www.pcmag.com/article2/0,1759,1620763,00.asp
  11. Digital Device User Ron B's Avatar
    Mar 2003
    The Gorge
    I'm sure this has been explained in other places, but if you have a Super8 projector and a digital video camera, and that's all you want to use, this is what I've done:
    Run the projector with no film on a white piece of cardboard/matte board. Try to find board that is not too reflective nor has a lot of texture. Mount your camera next to the projector, try to get the lens of the projector and the lens of the camera as close together as possible to eliminate parallax effects. Use the camera zoom to match the size of the projected image. Set manual focus and manual white balance while the projector is running without film. Try to match the shutter speed of the camera to the speed of the projector. You'll be able to see the amount of "flicker" in your DV camera. Most likely there will be a bit of flicker, do the best you can.
    Once it's set up, run your movies. It helps to clean the film, but be careful, at this stage of the game, most Super8 film is old and fragile.
    This may not be the ideal situation, but all you need is a projector and DV camera. If you have valuable footage, let a pro telecine company take care of it.
