  1. Im trying to get episode one on to svcd format with all the deleted sceens re omited to see what it would of been like. Ive got all files ready in mpeg 2 svcd (pal) format but cant seem to be able to join them and cut out the bits they are replacing. The problem seems to be with TMPGenc it keeps crasshing, can any one help me out here?
    May 2001
    mars
    You wouldn't have missed much if you re-omitted the scenes...that is for sure.
    I personally would clip the scene at the entry point then join the two and then join with rest of movie.
    Quite a pain to do in TMPG but it is the only way that I can think other then Premiere or other editing software.
  3. where can i get premiere or somthing a bit more stable, preferably for free
    cheers
  4. Well, you can always try using VirtualDub then frame serving back into TMPGenc. Maybe that'll work ..?
    -= The VidKid =-
    www.TheVidKid.com
    If you want my ICQ#, MSN or Yahoo Messenger ID, just ask. :)
