I know that TMPGEnc Plus gives me an option to shutdown the system after encoding, but how about an option to just shut down the program? Is this possible?
BG
Hi bgrieb,
I don't believe that that option is available. However, this post in the Pegasys forums (makers of TMPGenc) suggests that you've limited scope for running TMPGEnc from the command line.
My experience of command line tools is that they close after they've done their bit (or they can be instructed to). Might be the case for TMPGEnc...
If you have any luck, report back for others to benefit from...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the link. I'll play around with the idea they're suggesting and post results if I can get the desired effect.
BG -
No problem - it'll be interesting to see how you get on.
I'm quietly optimistic - boot from the command line, run a batch (even if it's just one project to encode), close (hopefully) when done...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 13:12
