Hello
After I ripped all vobto harddrive i used DVD2AVI and saved a projekt, resulting in projekt-file and a wav.file.
I did a vfapi conversion and opend virtualdub, selected video and wav-sound. But here is the problem the audio is 46sec(46300ms)out of sync, same issue when i open the files in TMPGEnc. Isn't this a little much for a sync-error?
I tried VOB2Audio and Grapheditor but didn't get any of them to work. In Vob2Audio i cant select stream (even tried making my own streamlist) and Grapheditor only shows video-options.
this is something dead-simple to consider, but did you wait for the audio to completely finish decoding in dvd2avi?
if the .wav is outta sync by the same amount in the entire movie....try using the source frame range filter in tmpgenc...it has an option called audio skew that you can use to get the .wav to sync up....but u have to know exactly how much it's outta sync in milliseconds
try to go to http://www.doom9.net and go to the guides then to VCD&SVCD guides and all the way on the botom is a guide yo fix this
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
