I have downloaded the mplayer codecs from:
http://www.mplayerhq.hu/homepage/design7/dload.html
(the essential codec pack)
for linux and want to install it but all I have is a folder with all the codecs. Is there a way to install these? Should I just copy all of them to a folder (which one)?
Thanks.
Garibaldi
Just found this quick little blurb.
You have to uncompress the contents of the codec pack archive into the directory
<installed path>/mplayer/codecs, mplayer will use it automatically -
I'm booted into XP right now, but the next time I boot into Fedora, I'll check those dirs to be sure.
Vid quality better in MPC (Windows), than MPlayer (Linux)...
By cwb in forum Software PlayingReplies: 3Last Post: 5th May 2010, 21:01 -
I would like to install Linux
By DVDONE in forum LinuxReplies: 2Last Post: 27th Apr 2010, 10:19 -
What codecs should I install? Which are the best?
By DonGallego28 in forum Newbie / General discussionsReplies: 29Last Post: 22nd Sep 2009, 12:23 -
can't play rm in mplayer on mac osx--did install reallib codecs
By onesuch in forum MacReplies: 2Last Post: 20th Dec 2007, 00:56 -
Linux won't install
By lordsmurf in forum LinuxReplies: 1Last Post: 13th Aug 2007, 10:59
