i was reading this divx guide and a guy said if you are doing a multipass divx that you should disable "update log file" in the divx encoder when you are on the last pass. i also wanted to know what is the difference with fast recompress and full processing mode in virtual dub mod. (is there any quality difference?) please anwser. please
Seeing as no one has responded in more than 130 views it might be safe to say that you have a better chance of getting your question answered by the forum at www.divx.com
Could be this forum deals more with DVD compliant video.Originally Posted by NickSaunders
HDDVD,
I would venture to guess that yes there would be a quality hit between the two settings. If there wasn't why would there even be a slower option? -
There is no quality difference between the 2 ways of compressing. Full Compression is needed if you are using VirtualDub filters. Fast Compression can be used if no filters are being used or the input file is, for example, an AviSynth script and the filtering is being done within that.
Full recompression fully decodes the frames to RGB then recompresses them. Fast recompression leaves the frames in the YUV colorspace (the native colorspace used by all the MPEG1/2/4 codecs) for recompression. This results in faster performance because you don't bother converting to and from RGB and slightly less picture degredation because the YUV to RGB to YUV conversion isn't perfect. Ie:
full: MPEG -> YUV -> RGB -> YUV -> MPEG
fast: MPEG -> YUV -> MPEG
New guy saying hi
By Hanssen069 in forum Off topicReplies: 13Last Post: 8th Jul 2011, 17:20 -
Day In the Life of an IT Guy
By Soopafresh in forum Off topicReplies: 5Last Post: 1st Sep 2008, 04:59 -
new guy
By harrisonhouse in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2008, 07:03 -
How did this guy get on tv?
By redstripes in forum Off topicReplies: 2Last Post: 25th Jan 2008, 16:31 -
Who is this guy that is trying so hard???
By fLYtRap in forum ComputerReplies: 12Last Post: 1st Jul 2007, 17:06
