Hi guys
I have a dvd-9 and I want to split it into 2 dvds-5
I tried DVDRemake but when I tried to change the
links of the buttons I missed it up![]()
there are alot of weird terms such as
cell , program , PCG they seem to be some kind of programing
things ??? I don`t know
If there is someone who can help me in doing this I`ll appreciate
that![]()
Thanks anyway![]()
try using dvd shrink to split to 2- dvd-5 discs. here's a guide on how to split it using dvd shrink:
http://www.dvd-guides.com/content/view/48/59/ -
DVDShrink method is simple but it doesn't keep original menu's just in case you want them
did you try following the guide if you want menu's and insert a swap DVD graphic?
https://www.videohelp.com/guides.php?guideid=585#585 -
One of my favorite way's to split a DVD to two disks:
- re-author movie-only with DVDShrink for disk 1, with mild compression if neccessary
- full backup with DVDShrink for disk 2, setting main movie to still image
A major advantage of this appoach is that it doesn't create a flipper - you don't have to get up half way through the movie to change the disk. The approach is also dead simple.
If you're working with a disk where the movie and all the extras are about the same size, you can alternately do disk 1 as full backup setting all the extras to still image.
Back up 1 title track split across 2 DL DVDs
By soneman in forum DVD RippingReplies: 11Last Post: 24th Mar 2010, 05:50 -
Large MKV split on two DVDs
By bjb39 in forum MacReplies: 2Last Post: 1st Dec 2009, 21:01 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Movie split on to 2 DVDs - make 1 movie.
By mattstan in forum EditingReplies: 3Last Post: 24th Oct 2008, 10:54 -
Automatically split a video to 2 dvds
By cd090580 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2008, 17:56
