Has anyone succeeded in frameserving from Sony Vegas Movie Studio? If I use the debugmode frameserver all I get is a file with audio and no video.
VFAPI gives an error every time I try and use it with Movie Studio - it says it can't accept the format (no matter what the format).
Even when I do get the blank video file with the debugmode frameserver, Movie Studio still spends all the usual time rendering the file, which defeats the purpose of frameserving even if I could get a file with video.
I want to edit in Movie Studio, frameserve out (without rendering) and encode in TMPGEnc. Any ideas?
Thanks,
trock
Results 1 to 10 of 10
can you play the frame served file in media player?
no mater what -- if there are effects or such (other than straight cuts) , the file will have to be rendered at some point .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
movie studio and Vegas will accept vfapi frame served files - no problems .. do it all the time ..
check your vfapi installation"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I know that but that's not what I'm trying to do - I'm trying to frameserve out of Movie Studio not in. And it's files that only have straight cuts.movie studio and Vegas will accept vfapi frame served files - no problems .. do it all the time ..
I do it all the time out of Vdub without problems but I haven't been able to get Movie Studio to do it. And in looking across many forums across the web, many others are having trouble with it. I was hoping that maybe someone here had successfully figured out a way.
trock -
then if you are going OUT of movie studio , what has vfapi have to do with anything ?
the only frame server (out) that works with movie studio is the debugmode one ...
straight cuts - movie studio will not re-render if your project properties match the source properties and it is a dv file.."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i briefly looked at the official movie studio sony forum , and didnt see any one having any problems like this (or much of any other)
I came across the problems at the Sony forum and the debugmode forums by searching on frameserving and Movie Studio.I briefly looked at the official movie studio sony forum , and didnt see any one having any problems like this (or much of any other)
I'm evaluating Movie Studio with a view to purchasing it and I just want to be able to frameserve from it but when I looked for how others were successfully doing it all I could find so far are others complaining about the same blank video or other problems (which I don't have). -
ahh - well that is no good ....
pick up a copy of vegas 4 instead (older version) , you can buy them for about the same as movie studio and a lot more features (and the frame serving works)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
on ebay i see for less than $100 for the whole package:
vegas 4
acid 4
sound forge 7
dvd author 1
and a bunch of extra stuff -- all legal ....
3 hours left"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How to hide something with Sony Vegas Movie Studio?
By sdsumike619 in forum EditingReplies: 8Last Post: 14th Jan 2012, 18:09 -
Sony Vegas Movie Studio HD Settings
By brazen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Feb 2011, 23:50 -
Sony Vegas Movie Studio 8 Question
By Quackulator in forum EditingReplies: 2Last Post: 15th Feb 2009, 18:35 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 16:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53
