Thx
Download TMPEG. Install it. Run it and load your DivX. Load a VCD or SVCD template. Hit Start. Take a nap. Wake up and see if it's finished. Hmmm, not yet, go to bed again. Wake up some hours later. Go to the computer and you have yourself a not so nice VCD-SVCD file which just needs optional cutting and burning.
OK how do I make a NICER VCD or SVCD? your previous answer did not need to be so "snooty"
PR-GUY: did you bother to read the tutorials that are located in the side bar?
http://www.vcdhelp.com/convert.htm
or
http://www.vcdhelp.com/tmpgenc.htm for VCD
or
http://www.vcdhelp.com/tmpgencsvcd.htm for SVCD
check there before you post.
-Mark -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You actucally asked for the easiest method... which that is. Beware though, the results aren't going to be great. CCE for SVCD, TMPGEnc for VCD. Try smoothers (temporal or spatial). And pray.. a lot.
Guides for that stuff to the left. For filters your probably going to need to frameserve from vdub. -
Well said Shabubu and z68h.
Pr-guy, that wasn't "snotty". It was an appropriate 60-word answer to your inappropriate 1 word question. Nothing personal -
PR guy thought he was getting the brush off; the rest of us are laughing, sayiong "yeah.. take a nap, that's for sure.." because it takes a long time. Seriously though; "HOW" is covered over and over in those green links you should see on th left of the page. The ones that say "HOW TO" at the top.
Best/Easiest way to make multiple segments of a mp3 file?
By raydeneg in forum AudioReplies: 4Last Post: 7th Oct 2008, 09:47 -
Easiest Way on Mac and PC To Make Audio CD From DVD
By MacPCConsultants in forum DVD RippingReplies: 2Last Post: 26th Feb 2008, 08:18 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Whats the cheapest, easiest way to make a webcast on my site?
By nato17 in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 19:06 -
Easiest way to make a 16:9 DVD into a 4:3 XViD?
By bconnolly in forum DVD RippingReplies: 10Last Post: 31st May 2007, 16:54
