hey guys,
I have a quick question,
I have two old video and audio clips that I am trying to merge together. These files are back from the days before I had a dvd burner, so I split the original video file in two and put them on two cds as vcd's. I now want to rejoin them and then re-encode it and burn it to dvd. How do I join the two video and audio files without causing an a/v sync issue? what program would be best to use?
thanks,
sincerely,
schunn99
TMPGEnc will do this, and so will TMPGEnc DVD Author. Easily join two or more parts into one seamless clip without any need to re-encode.
"Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
If you want to guarantee that you will have no sync issues then it's best not to join the clips. Author them so that they play one after the other.
Need help again, Re: A/V sync issue :(
By takearushfan in forum AudioReplies: 8Last Post: 1st Sep 2010, 12:32 -
corrupt video file preventing authoring?
By feh in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 13:41 -
Audio sync issue
By Nightshiver in forum AudioReplies: 10Last Post: 2nd May 2008, 18:37 -
Preventing DVDFab HD Decrypter transcoding (shrinking) your files
By mazinz in forum DVD RippingReplies: 4Last Post: 30th Jan 2008, 18:08 -
ffmpeg.exe preventing upload of asset
By daz72 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Aug 2007, 03:27
