Hello everyone, I have a .bin file that I want to convert to VCD......it's an 800MB movie but I don't know how convert it so that I can watch it on my DVD / VCD Player.....can somebody please tell me what to do??
Results 1 to 13 of 13
Simply burn it as a VCD in Nero. If you need it to be converted back to .MPG, try VCDGear. It will take only a couple of minutes to do. You could also try VCDEasy.
Your signature is too large. Please read the Forum AUP, and reduce it so it is the correct size. The AUP can be found here:
https://www.videohelp.com/forum/viewtopic.php?t=124514
/ Moderator Cobra -
first of all sorry about the size of my sig but I've changed it......neways, If I want to convert it back to MPG, would TMPGenc Plus work? cuz since it's like 800MB or more than that, it might not fit on a VCD....I might have to split it up and I know I can do in TMPGenc....would it work???
Follow the link Zippy supplied. If that's too difficult, here it is again. Read it. It tells you exactly what to do.Originally Posted by yhe2x
The other option is to not convert your source to bin (an image file) in the first place, making sure you convert to VCD compliant MPEG-1.
It's also a very frequently asked question, so next time, have a look through a few of the forums and see if there is a sticky that addresses your issue. You'll find your answer much faster
If in doubt, Google it. -
I did read some topics regarding this but I didn't quite get it, I guess I'm too dumb......sorry about that but I'll try those guides you gave me.....thanks again//
well it worked just perfectly!.....i used ISObuster to extract the MPG from the bin file and was able to convert it back to MPG and burned onto a VCD.....just have one last question tho....so what exactly is a .bin file??.....is it like .dat file on a VCD except it's on a DVD format?.....Thanks again..
A .bin file is a binary file that contains information used by an .exe file
A bin is an image of a disk and is usually found with a cue file which gives the directions for burning to your burning software.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 02:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 08:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
