Hi, I want to buy a DVD standalone recorder but before I want to know if I can use all kind of DVD speed support (4x-8x-16x) or I can use only some speed support (ex. <4x). (I know that DVD recorder can write only at 1x but what happens if I use 4x DVD+RW that is manufactered only to write for 2x and 4x speed?)
I asked to LG customer support (I want to buy LG DR4912 dual format DVD recorder) but they cannot say answer to me.
Thanks in advance,
Davide
Davide - Italy -
EDITED
I've used up to 4x blanks. It works on all but HQ speed.
I was comparing HQ recording on cheap 2.4x with cheap 4x disk.
The 2.4x froze the moving logo (CMV) at the beginning
the 4x did not.
Also the 2.4x skipped and froze from 45minutes on.
The 4x did not until 50 minutes.
Both were cheap supermedia.com disks
I assumed the newest firmware would handle the newer disks.
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
want to buy a Philips HDR3500 recorder but need to know if USB is Hi-speed
By renavasc in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Oct 2008, 13:28 -
converting to AVI or mp4 with stand alond dvd recorder..speed test
By diablo_ogre in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:55 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
