  1. Hy everyone,
    I'm trying to use DVDx with avisynth to convert with external encoder TMPGEnc. I open DVDx and then set the frame server... open TMPGEnc and when I choose the avs file as video source it send me a message "File "c:/part.avs" can not open or unsupported" What can I do??? It's better a constant bitrate or variable bitrate???
  2. mkae sure to uncheck directshows filter
  3. and here is how you do it go to options-> enviormental setting-vpafi and uncheck the directshow filter
  4. Excuse me for late but I have to work for living. Yes I've done but the same result
  5. try this on DVDx check multi pass..that might help
  6. I'm sorry but I can't understand "try what..." but what???
    Aug 2001
    Västerås, Sweden
    check multi pass
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  8. Yes I've done but the same result yet....Thanks for your time and excuse me for my bad English...
