How can i split a avi file in to two seperate files
so i can edit them then put them back together
Use Virtual Dub.
1. Load the Video
2. Select File=>Save Wav...
3. Use the original file for video only.Hello. -
When i save audio as wave will it compress it at all?, and will i be able to save it as ac3 6 channel audio?
It's your choice. VDub can either just demux the audio, leaving it in the same shape it was before it was interleaved in the AVI, or be processed to a different format - which, depends on what audio codecs you have on your system.Originally Posted by Shifty268
/Mats -
Is there anyway i acn just split the avi file into audio and video
two files. -
Again:
Load AVI in VirtualDub.
Select "Direct stream copy" under Audio, then "Save WAV" Now you got the audio as one file, in the format it is in the original AVI, but with .wav exyension.
Now, select "No audio" under Audio, "Direct Stream Copy" under Video, then Save as AVI. This gives you a video only AVI, with the same characteristics as your source AVI.
/Mats
AVI - audio remove, video split, music merge
By kj1983 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2012, 02:59 -
Best program to split .ts audio from video?
By R55B in forum EditingReplies: 1Last Post: 30th Oct 2010, 08:09 -
Need to split HD video saved in avi mode.
By jones24 in forum Newbie / General discussionsReplies: 22Last Post: 14th Aug 2009, 12:16 -
easiest way to split audio and video
By ir0n_ma1den in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2009, 20:21 -
Need to split AVI due audio problems
By Squid_uk in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jun 2007, 07:35
