Hi, i have a problem with dvd-lab pro. this is the situation. i have 2 movies and they're both avi files. i used dvd santa to convert the movies to dvd files(VOB Files). i used to use TMPGenc plus, but i had a problem with TMPGenc. so i prefer dvd santa. so now, i have VOB files, i played the dvd files from dvd santa, and it worked great. it has audio, video, and the 2 movies. the only problem was, it has no dvd menu. so i used dvd-lab to create the menu. so i add the vob files to basket bin and chose to joined the vob files together. everything looked ok, so i compiled it. the compiling was done, and i check the new dvd files from dvd-lab. the menu is ok but when i play the movie it has no sound. so is there anything i should change with dvd-lab setting? or is there any software i could use to make menu with vob files? i really need your help, thankz to everyone who bother to check out my problem. thankz
IIRC, DVD-Lab only allows one audio format per vts (only dvd-lab pro offers more than one vts). As such, your dvd writer is picking up one audio track and using that as your standard and essentially ignores the rest. You'll have to jump back into things and make sure that ALL of your audio is the exact same format. Alternatively, you can try dvd-lab pro and set up multiple audio tracks.
thankz for the reply. i have dvd-lab pro, thats the one i used for creating the menu. and what do you mean by its only picking up one audio? the dvd files dont have any audio, so its not picking up anything. i tried using the ifoedit, and it works ok. the new ifos created by ifoedit gave audio to the movies but i lost the dvd menu. so i think the problem is the ifos that was created by dvd-lab pro.
how can I use .SUP files with DVD Lab Pro
By taasan in forum SubtitleReplies: 23Last Post: 7th Jan 2013, 08:09 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 20:28 -
Vob File has a aspect ratio of 704X480 in Dvd Lab Pro.
By mlong30 in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 00:24
