I have been using virtualdub and TMPEG to convert my VHS captures to DVD's. I am quite happy with it except that it takes a bit too long on my P3 machine.
Last week, I wanted to try Aviscript (using avisynth 2.54) with TMPEG to boost up the speed a bit. I have succeeded with it, but , suddely I realsied one funny problem.
When I load the multisegemeted avi (captured with Virtualdub), in Virtualdub, it showed a total duration of 2 hrs. and 27 minutes. But when I loaded the same into aviscript, it showed only 2 hrs. and 20 minutes in the preview window. What happend to the 7 minutes of the clip in aviscipt?
I tried one more thing. I generated the avs file with aviscript and then loaded it into visrtualdub. This time it is only 2 hrs and 20 minutes in Virtualdub as well. I am totally perplexed!!!
Can some one help please?
Did you make sure the frame rate stayed the same?
Hello. -
Yes, I checked the frame rate, but this is how I checked.
I do not know how to check the frame rate in aviscript. So, I checked the framerate under 'Video' in virtualdub for the original video as well as the avs file. Both showed 25 (I am using PAL).
Is there anything esle that I should be looking at?
Thanks any way. -
Well, some apps use the audio for duration. Others use Video. I always ignore the duration, and just make sure I have synch when I encode.
Hello. -
Hi,
I just realised the problem. One of the files of the segmented AVI, Capture.04 had a bad frame 0 (I found this out when I loaded the segments one by one in a test avs script, and got the error message 'cannot decompress frame 0).
Is it a bug in it that aviscript, when comes across a bad segment, just ignores it, loads all other segments and doesn't even give an error message?
Aviscript
By kemo1000 in forum EditingReplies: 4Last Post: 14th Jan 2012, 08:43 -
AVIScript Line25 error
By pboong in forum Video ConversionReplies: 25Last Post: 24th Aug 2010, 06:35 -
W7 + AviSynth + VC-1 = problem?
By follz20 in forum Video ConversionReplies: 5Last Post: 5th May 2010, 12:16 -
AviSynth Script Problem
By Eva-Unit01 in forum EditingReplies: 21Last Post: 29th Dec 2009, 12:00 -
Avisynth Directshowsource Problem
By Robert Simandl in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 07:41
