I'm having trouble with my burner for some reason it only writes dvd+r's and 4x (using verbatim 8x "mcc 003") and cdr's at 16x(using memorex 40x"97m26s66f") I've updated the firmware to 2.16 and I have the newest version of nero. I included the product codes for the discs. It's all running on a amd 2500+ barton with 512 ram. Am I doing something wrong??? Is there no way to get around these speed locks??
Which version of Nero?
One version locked out bitsetting on my 2500, at FW 1.06, but I can't recall which.
Try uninstalling and going back a couple.
I think you can find the previous vers at cdfreaks.com
Post again if you need more. Think I am gonna UG mine to 2510, just for the hell of it.
Cheers,
George
4 days, no response, you must feel like no-one gives a damn, huh? Stick around. Some do. -
nero I have installed is 6.6.0.1 I tried some TDK 8x dvd+r's and still the same slow burn I tried burning with easy cd 6 and it would only burn at 2x. I saw that the 1.07 v2 beta5 firmware is the one that people recommend but when I try to flash it it says couldn't locate 2500 drive. Nero says that it's burning at 8x but the time to burn a full dvd is still 30 minutes so I'm not sure what to do..
Check here:
http://club.cdfreaks.com/forumdisplay.php?s=&daysprune=&f=86
The problem is with your firmware, but you have to do a few things before you can change it to the 1.07 v2 beta5. I can't remember them right off hand but I found how to do it there.
Good luck.
What happens when you 'delete' stuff from a DVD before writing to DVDR
By mtdg in forum DVD RippingReplies: 9Last Post: 7th Nov 2008, 09:51 -
DVD writing speed
By DrAlanStatham in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 13:43 -
DVD writing speed problem
By dmckay2007 in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 17:38 -
Pioneer 111L only writing at 1.9x speed don't why. Please Help
By bnbhoha in forum DVD & Blu-ray WritersReplies: 9Last Post: 26th Jun 2007, 11:58 -
How do i change the default writing speed in Nero when using DVDshrink?
By wallacem4141 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 06:15
