I have a very low end PC with a USB 1.1 connection using ADS DVD Xpress, and CapWiz to capture video. Unfortunatley with CapWiz I can't caqpture video over 2.0mb/sec for as long as 20 mins, because at that point the video distorts. I'm looking for alternatives and attempted using WinDV, it does recognise the USB connection as Cirrus Logic USB-DVR2 Source, however when plugged in an error appears -''Can't find DV output pin''. Thanks for any assistance.
As far as I know, WINDV is just for Firewire connections and a DV signal. But there should be other programs that should work with USB.
If you have a open PCI slot, why not get a PCI USB2.0 card? They are cheap enough and will get you away from slow USB1.0 connection problems.
capturing through usb on HV30
By birdclaw in forum Capturing and VCRReplies: 5Last Post: 7th Dec 2010, 11:29 -
Elura 70 Capturing DV to laptop with USB ports only
By knighttknight in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 13:15 -
USB capturing???
By Rayza1 in forum Capturing and VCRReplies: 10Last Post: 31st May 2010, 04:45 -
Cannot use windv with usb
By Riff88 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2009, 16:04 -
WinDV Capturing Problem
By ViperUKR in forum Capturing and VCRReplies: 12Last Post: 27th Jul 2007, 00:14
