After selecting a avi file for encoding Tmpgenc analyses the field order, resolution etc..it says video size is 704X480...i know for sure my files are DV files 720X480..I even generated a file using a 720X480 bmp picture.
reinstaiing the tmpenc didnt help..any suggestions why is this happening/how to fix it??
Hmmm... Odd. Not seen that one.
Have you tried doing a test encode of a short clip (say 30 seconds) to see what the resolution is of the resultant MPEG? I'm assuming you're planning to go to DVD at 720 x 480...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I get this too. Do you use Mediastudio or any program made by ULEAD to capture your video initially? I use Mediastudio. In TMPEG I just change it from 704 to 720 and it takes it but it does initially see my video as 704.Originally Posted by tonyzzYour miserable life is not worth the reversal of a Custer decision.
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
