Results 1 to 9 of 9
    Feb 2004
    Anyone have a good .mov editor with the Similar feature as MPEG Streamclip www.alfanet.it/squared5
    Sep 2003
    London
    Goldberg
    Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
  3. iMovie?
    Keeper of the "Unofficial" iMovie FAQ also for the lastest iMovie news click here
    Your source for iMovie answers and what not! ;-)
  4. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    FCP or FCE... QT Pro is usually sufficient for my needs, otherwise iMovie works, but I usually stay in a DV format workflow... until I export to MPEG2 and AC3 for DVD.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    Feb 2004
    Originally Posted by bendermac
    My preference but qt pro doesn't seem to let me trim the areas I want to and the slide bar is difficult to accurately place on the exact time code I want so that I can edit it properly.
    Originally Posted by mhar4
    Goldberg
    Doesn't give the option to edit the .mov file.
    Originally Posted by DanSlagle
    iMovie?
    The problem is that i have to convert the .mov to a dvstream. Trying to stay in the .mov format so I don't wait for conversion and then encoding.
    If FCP or FCE is the only option I suppose it's a worth while investment.
    also found this
    http://www.arboretum.com/
    thanks for all the input
  6. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    All you do is click the editting triangle then use the arrow keys. You can go frame by frame, that should be accurate enough
    Feb 2004
    thanks for the tip.. greatly appreciate.. it was driving me nuts.
    Sep 2003
    London
    Goldberg
    Hold down SHIFT and move the slider. Use the cursor arrows, too. Cut/copy/paste. Works nicely. Easier than QT Pro, I think.
