Hoping somebody can help:
I've noticed a range of problems recently with my computer, both related to making home movies and beyond (eg. webcam not working).
I think the problem is with DirectX. When I run dxdiag from the RUN prompt it cannot detect a version of DirectX, plus it says a number of .dll files are missing.
Having found all those files on the net I tried adding them to SYSTEM32 folder, which dxdiag now recognise but say they're old versions so might still cause a problem. Plus it still won't identify directX is present.
I've also tried reinstalling directx 8.1 and 9 and both say installation compete and working but dxdiag still says different and the problems are still there.
I've searched high and low for a solution, really help somebody can help here.
Thanks in advance for suggestions.
Chris
Hello,
You probably don't want to hear this but a complete reformat of the harddrive would be the easiest option.
I had problems with direct x awhile back but a reformat took care of it
If you do do it backup up EVERYTHING and then give it a go.
Good luck.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Could a .TS Video with an Audio Error be Repaired?
By zoomie in forum EditingReplies: 3Last Post: 7th Feb 2012, 14:16 -
DirectX
By CSULB71 in forum ComputerReplies: 4Last Post: 12th Jul 2009, 16:13 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
The dreaded 360 ring of death -REPAIRED!
By yoda313 in forum Off topicReplies: 11Last Post: 28th Jun 2008, 09:37 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51
