I wonder how long is the maximum file size(min) you can put on a 80 min CD-R, and what are specs for that?
And can you skip/alter some options like bitrate for the sound to get more on a disc?
Thanks in advance
Depends on the size of the video and the cdr media used.
740mb on a 650mb
800mb on a 700mb
990mb on a 850mb
Max video bitrate can be 2496kps and audio 224kps
You can have up to 39 minutes of svcd using the above bitrates on a 700mb cdr or 49mins on a cdr99.
You didn't say whether you were using svcd or vcd
74minutes on a cdr650 using vcd
80minutes on a cdr700
99minutes on a cdr850
Hope i got that right. For more info just look at the guides on this website, thats how i got started.
David -
Some additional info in german can be found on
http://www.uchrin.de/svcd/234_cd_ausnutzen.htm
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 17:02 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 03:41 -
Embedded attached picture (covert art) max size
By Brazil in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2009, 06:56 -
Max Hard Disc Size on PS3?
By SCDVD in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2008, 04:11 -
Sony Video Capture 6 (Vegas MS) hard drive max size limit?
By distendo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jun 2008, 09:02
