If I encode an mpeg2 with a good software encoder (like cinemacraft) as per the mpeg specifications, giving maximum work for the encoder in terms of complexity, will I get a video file with quality on par with that of hardware encoder? It is assumed that the source footage is very good. It is also assumed that time factor is not a constraint.
Thanking you in advance for your reply.
please post conversion/encoding questions in our conversion forums. moving you.
In my experience [https://www.videohelp.com/forum/viewtopic.php?t=244130] you obtain better results transcoding from avi to mpeg rather than encoding directly, via hardware, to mpeg file.
In this forum and Canopus forum have been reported same results.
If you search you' ll find them. -
Neither method is inherently better than the other. Just as there are crappy software encoders, there's crappy hardware encoders.
/Mats -
You really need a proffessional to answer this, but my bet would be that given enough cash, a top level hardware encoder will be as good as the best SW encoders. At the consumer level, or even so called pro-sumer level, IMHO, SW encoders win practically everytime.Originally Posted by Premjit V.P.
Hardware encoders do the job in realtime and then they may have trubble encoding difficult scenes. Softwares take all the time they need and obtain this way better results.
Of course I,m speaking about hardware encoders at consumer level -
That is not necessarily so. But you perhaps think about hardware encoders in terms of "capture card"? You could well "imagine" hardware encoders that reads AVI files, and don't have to perform their task in realtime...Originally Posted by scardi
/Mats
Mpeg2 to Mac lowers the video quality?
By Ryuran333 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Feb 2010, 21:51 -
RMVB Convert to Mpeg2 quality
By anfield7 in forum Video ConversionReplies: 1Last Post: 10th Dec 2008, 22:58 -
mpeg2 to mpeg4 video quality
By Starkian in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 09:36 -
mpeg2 to mpeg2 lower quality...
By zovx in forum DVD RippingReplies: 4Last Post: 6th Feb 2008, 16:36 -
Best quality (Not speed) Converter for miniDV to Mpeg2
By AussieHusky in forum Video ConversionReplies: 5Last Post: 2nd Nov 2007, 00:54
