Hi!
What's the easiest way to convert a DVD back to MPEG2?
Please note that I want to convert it to MPEG2 with identical bitrate just like it was in DVD format. With other words, tools like EasyVCD (with ability of extraction DVD>SVCD but with preset, and considerably lower bitrate) is useless in my case.
Thanks in advance!
you don't have to convert at all,
https://www.videohelp.com/guides.php?guideid=638&howtoselect=3;6#638 -
you simply demultiplex the content of (I'm assuming) the main movie with some tool like tmpecenc (under mpeg tools), womble, (I believe) cuttermaran etc.
To rip the main movie use decrypter in IFO mode and select the longest pgc (which should reasonably be what you're after).Sorry, I had to go see about a girl
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
Stripping & Appending / "engage use_codec_state" ... MKVmerge / splitMKV
By salinsky in forum SubtitleReplies: 2Last Post: 14th May 2011, 10:41 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 14:59 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 17:25 -
Eliminating "Tearing" effect in 2D games with Vsync & Triple
By retroborg in forum ComputerReplies: 1Last Post: 17th Dec 2007, 11:50
