  1. Has anyone got the DVD font? or know where to get it (the one with the dvd logo's, dolby digital, region 1&2 etc.) I had it installed but re-set my pc back to the factory settings and it's now gone and don't know where i got it from (it must have been on a prog i had previousley installed)
    Help!
    I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
    Rufus T. Firefly (Groucho Marx)
  2. its called Combi Symbols DV
    dont have it unfortunately
  3. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  4. troll is da man
    thx dude
  5. that's great! thanks for that, i dont suppose you have the one with the different region globes etc?
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    OK....I'm dumb. What exactly are those things? What format is that? My computer opens a full page of logos. Not sure that I would ever use those though....but they look like fun to play with.
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    That's pretty kewl !
    If in doubt, Google it.
