I have ripped a few DVD's and when playing the VCD back on a standalone unit the audio seems to skip every 5 seconds or so. I have tried playing the VCD on 5 players now and they all do the same. It will play alright on my computer though. any thoughts???
try switching media(cd-rw springs to mind) or burn at a slower speed. check the properties(resolution, bitrate) of the mpg while you're at it
Thanks Stan. I know for sure that the bit rate and resolution are correct. I havent as yet burnt at a lower speed. Im not sure if this will fix the problem though because it seems to be alright playing on my computer.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
FAVC dropping 6 channel audio
By midders in forum DVD RippingReplies: 3Last Post: 10th Mar 2009, 19:36 -
MKV to MPEG2 - Not dropping frames, but not smooth - think it's audio
By Shade00 in forum Video ConversionReplies: 11Last Post: 18th Feb 2008, 13:20 -
DVDx dropping audio at end of vob
By shira in forum DVD RippingReplies: 0Last Post: 21st Jan 2008, 22:42 -
Dropping audio on capture
By joe1541 in forum Capturing and VCRReplies: 5Last Post: 28th Oct 2007, 19:07
