Alright, I have a movie its 3 cds... and it has 3 .bins but I do'nt wanna put them all on 3 differ cd-rs can I just put them all on a dvd-r? !
Also, not sure where to ask this, but I also have a game that is 3 .bins and I don't wanna burn them to 3cd-rs can I burn it to a dvd-r? and some how when installing it, it asks for the 2nd cd to be insterted will it read fromt he same dvd-r if its burned? Thx.. and sorry if this is a waste of ur time...
Results 1 to 13 of 13
only_emo_kidGuest
on the game issue - play it from the original disks , though you could maybe mount them as virtual disks also from your back ups..
on the movie -- just back up the original DVD , otherwise you will have to convert the cd's to a DVD format ..
there is a subtle hint here .... :
Look in 'Tools' under ISO. You can convert the .BIN files to MPEG2 and then combine them. Of course they are probably SVCD or XVID, so there is a little more work involved to get to a DVD. SVCD2DVD or TheFilmMachine (For XVIDs) are two simple ways.
Not sure about the game CDs combined on a DVD. Might depend on how the game sets up. -
For extracting stuff out of bins, try here.
...Or you could try this sticky.
I got a funny feeling I know what BJ_M is implying too ...
If in doubt, Google it. -
Gotta love the subtle hints
Yeah, but I just skimmed it. Looks pretty involved and I was too lazy to read every wordOriginally Posted by jimmalenko
You mean this link right?:
http://www.iecc.com/gclist/GC-faq.html -
Yep. I was laughing at the fact that you answered like a total newbie in that you skimmed over it, it looked too hard, yada yada yada .... and so on.Originally Posted by Capmaster
That link was all about extracting garbage from bins, quite relevant for this forum I thought
i think this link is better
http://www.ci.asheville.nc.us/works/Auto.htm"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Burn Multiple ISO's to one DVD with Menu
By AHWagner in forum Authoring (DVD)Replies: 10Last Post: 4th Jul 2011, 19:54 -
choice: burn to single BD, or multiple movies in 264?
By jlm86 in forum Blu-ray RippingReplies: 15Last Post: 20th Feb 2011, 21:14 -
Possible to burn AVCHD to multiple discs?
By hiimbored in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Jan 2011, 18:55 -
burn multiple dvds with original menus
By pins123 in forum DVD RippingReplies: 1Last Post: 26th May 2010, 17:31 -
How do I burn multiple subtitle tracks to a DVD with ffmpegx
By wildgeese in forum ffmpegX general discussionReplies: 6Last Post: 26th Feb 2009, 12:54
