hi,
i'm having trouble formatting a rewrite after doing a quick format.
i think that went wrong as i can't put anything on the disc so, i thought i'll format it properly. But when i use windows or INCD i can't choose to start the formatting or erase as the start button is not accessable.
when i put it on a program to record it says the disc to blank, but won't record.
the disc on proberties says it's empty with 0MB left.
any ideas
many thanks in advance
Adam
Hi,
I am having the same problem with my Prince DVD-RW when I erase the disk everything seems to go ok but when I go to burn no it, it says there is no room...
Any ideas anyone? -
I have just noticed that the disks are 1-2 speed and I think I burnt @ 4 speed cause that is the default and I have never changed it...
What does that mean? Is that why I can't write on the disks?
Is there anything I can do to change that? -
I had this happen once with a Memorex DVD-RW and used DVDInfoPro (freeware) to reformat. Remember this only happened once so I am not sure if this always works or not.
u have to burn the lowest speed either ur burn speed or the disk speed otherwise they wont work
i read a lot
Formatting a DVD+RW
By V Bot in forum MediaReplies: 10Last Post: 28th Jul 2009, 14:09 -
Hard Drive Formatting Problem
By Captain315 in forum ComputerReplies: 13Last Post: 21st Mar 2009, 09:44 -
Formatting DVD+RW on Linux
By daithi_dearg in forum LinuxReplies: 4Last Post: 13th Mar 2009, 18:46 -
Problem Formatting Ext HDD Fat32 Partition
By Shaky Jake in forum ComputerReplies: 6Last Post: 3rd Jan 2009, 16:27 -
Problem formatting DVD+RWs
By Sephiroth666 in forum MediaReplies: 12Last Post: 12th May 2007, 12:51
