Is there a way find out the properties of already encoded MPEG-2?
Like: min, avg, max bitrate used, what audio compression was used and any other settings used during the original encoding process.
I want to edit the MPEG-2 and re-encode using Mainconcept Pro plugin in Adobe Premiere, and I 've heard that in order for the Mainconcept encoder to do smart rendering, you have to set all the settings the way the original file was encoded to.
Or is the software smart enough to detect to origianl setting?
Thanks for your help!
Some help needed, Trying to find the best approach to edit MPEG
By chadwill in forum EditingReplies: 14Last Post: 21st Aug 2009, 07:45 -
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 10:29 -
x264 encoded mkv/mp4 transcode to xvid encoded avi
By graysky in forum Video ConversionReplies: 4Last Post: 9th Aug 2008, 19:55 -
ConvertXtoDVD does it find optimal mpeg bitrate for you?
By supaguy in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 16:13 -
MPEG properties
By tonyaldr in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2007, 23:42
