I am finding that stuff encoded to NTSC seems to look a bit better. I am using Canopus Procoder and I think the reason may be that NTSC has only 480 horizontal lines as opposed to PAL's 576. When I encode to PAL it looks a bit more digitized. Kind of like one of them videophones the journalists use to report from war zones.
Also, do NTSC DVD-R discs cause any compatibility problems these days?? I read a post where someone said it's a minority of DVD players which do not play NTSC discs in the UK
Results 1 to 10 of 10
In europe you have dual-format equipment. In the US we don't, so we're stuck with NTSC.
PAL has more resolution, but a slower framerate. It's pretty much a wash which one looks better, IMO. But if you see a difference, and prefeNTSC, then you should have no trouble playing them in the UK. -
Its also TVs that need to NTSC Compatible too. The majority of TVs however do play both NTSC/PAL in the UK, even the old ones so it shouldn't be a problem.
Originally Posted by franco
Encode to whatever the source is. If the source is PAL encode to PAL, if NTSC encode to NTSC.
While it is true that PAL has fewer frames/sec than NTSC, people seem to manage quite well with the 23.976fps variant of NTSC.
Not only that, but it means the bitrate is spread between fewer frames for PAL, allowing a larger image.
If you live in the UK or are planning to use the video in the UK, leave it as whetever format it is in - that way you don't lose anything in the conversion process.Regards,
Rob -
Originally Posted by rhegedus
/Mats -
Originally Posted by mats.hogbergRegards,
Rob -
OK, I'm in the UK and what you want to know DEPENDS on:
a) the original framerate
and
b) the ORIGINAL resolution of the .avi
Lets start with framerate, if its a NTSC 23.97 or a 29.97 keep it, dont change it to PALs 25fps......unless you have a ancient/antiquidated TV...aply pulldownon 23.97's
Now, lets think of the .avi's resolution. Upscaling a 'typical (dloaded)' .avi (4:3 in this example), lets say 512 X 384 to 704 X 480 NTSC (on 720 X 480) is a upscale of 25% in the vertical (384>480) whilst a PAL is an upscale of 50% (384>576).
Remember TV's work on VERTICAL res (aka scan lines) so horizontal, although important, takes second place to VERTICAL.
No matter what you do you cant get MORE detail when upsizing, you can ONLY get more and more pixelated or 'softened' video footage as the magnification increases and obviously NTSC wins out over PAL in the above examples. BUT, (there's always a but isnt there?) hopefully as your in the UK you have a widescreen 16:9 TV, in which case you need to play the resolution game. You can encode with borders (16:9 PAL 4:3 format) which will DISPLAY at 480 high (borders not visible). Also dont bother with FULL DVD res (720 X ~) for the video, add borders regardless, using 688 X 560 (PAL) for instance, will show hardly any border (if any) and you can go lower still. Also the resize FILTER plays a part here as well.
The best thing you can do is:
a) Get a good encoder that accepts .avs files
b) Learn AVIsynth Frameserving
c) Ignore 'b' and use FITCD to see the resolutions available when upsizing, (dont go straight for the highest res)
d) Apply common sense and THINK about what you want.
e) Dont try STUPID upsizes...unless you want crap results.
f) USE FitCD (and try those resize options!!!!).
g) Did I mention FitCD??
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 17:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
