I am new to dvd burning.
I just burned "13 Ghosts" on a 4x dvd-r.
But my Samsung dvd-s221 doesn't seem to recognize it, shows me "check tv system" error message.
Any idea?
I suppose "-" is the way to go because my burner doesn't support bittype setting. Anything I have to notice when burning dvds?
Your movie and TV are mismatched. One is NTSC and the other PAL. Select the right TV format in the Samsung's setup screen.
You can't just switch formats. Your TV and DVD player are set up for NTSC by default, since you're in the US. We don't have the luxury of dual-format TV sets like the europeans have. :POriginally Posted by Traveler
You can't play PAL DVDs and view them on an NTSC-only TV, even if you can find a PAL option in the DVD player setup.
You need to transcode the DVD, or buy one that is in NTSC.
Or watch it only on your PC DVD player, which doesn't care what format it is. -
[quote="Capmaster"]
My APEX player can do this. Guess I lucked out.Originally Posted by Traveler
[quote="jyn999"]
Your player, sure. But what about your TV? Does the player convert everything to the TV's format? If so, where can I get one?Originally Posted by Capmaster
Newbie Question on Burning Bluray
By discover in forum Newbie / General discussionsReplies: 5Last Post: 23rd Feb 2012, 15:35 -
Newbie question RE: burning DVDs from HD camcorder
By lcinva in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Sep 2011, 09:53 -
Help a newbie with BR burning... please.... :)
By mefistofel_666 in forum DVD & Blu-ray WritersReplies: 8Last Post: 3rd Dec 2009, 17:11 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 22:31 -
Newbie Burning Failing
By mearm in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2007, 04:40
